Power Outage ICX 7150 not working . How do I find out the IP address for the device?
JL2477
power went out last week and I played around with the devices and luckily got it to work but now I am having no luck. reading these forums are not the easiest also. I've tried connecting to my computer via usb-c cable but no luck also. I think the main issue is I don't know what the IP address is for the unit.
5 REPLIES 5
Hi @JL2477
If the IP address is the issue, you need to fix the issue via console access, then can fix the issue with commands, let me add the guide to gain console access to the Switch via console and the other guide to fix your issue via CLI(command line interface)
How to console in the ICX-7150-12CP 'Ruckus Switch'
RUCKUS ICX 7150 USB TYPE C CONSOLE (tutorial video for ICX)
https://www.youtube.com/watch?v=YXR4xhkw3q8
(Tutorial for MAC)
https://www.youtube.com/watch?v=1AcJokMm78U
Once you gain access, run the next set of commands:
Commands:
show flash
copy flash flash secondary
write memory
show flash
Boot system flash primary yes
reload
Example:
ICX7150-C12 Router>enable
ICX7150-C12 Router>show flash  (you can confirm in which partition you have the correct code that will start with SPS example: SPS08080f.bin normally will be your primary partition)
ICX7150-C12 Router#copy flash flash secondary  (this will copy what is in your primary code to the secondary)
ICX7150-C12 Router# write memory
ICX7150-C12 Router#show flash  (now both partitions must start with the SPS before the code type)
ICX7150-C12 Router#Boot system flash primary yes
ICX7150-C12 Router#reload
Guides with more details tyo fix the issue(both are the same):
Guide#1:
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-Fix-Routing-code-issu...
Guide#2:
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-solve-the-routing-cod...
Yarenis Hernández
