01-11-2023 01:09 AM
I am needing help replacing the ICX7150-C12p. This is the second one that stopped working, I ha e tried multiple steps on fixing it from ports, to hard reset and it's still not working, I need approval from tech so I can provide the link to start my RMA process.
01-11-2023 06:09 AM
Hi @BILLYAZURDIA
Please follow the below steps to check the whether your switch is powering on or not.
3- Make sure it is plugged into a well-known outlet/power source
4- Are the Access Points R510 powering up?
5- Are you having any connectivity issues like webpage not loading or slow connectivity.
Also please provide an image/photo where you are trying to connect via console from ICX 7150 - C12 P (USB type C to USB ) to PC. Before uploading the photos please login to the RUCKUS account and you can upload the image.
01-11-2023 04:56 PM
Hi, was not successful with getting internet from ICX7150, please see the answers to the questions from above and adding the screenshot below
1. pugged it in to the ICX7150 and got no internet, tried multiple ports did not work.
2. Figure 1. Port-side LEDs of ICX 7150-C12P- only two lights are on
3. plugged in to a PowerSurge protector
4. Access Points R510 are not powering up
5. non internet. screenshot below
01-12-2023 04:55 AM
Hi @BILLYAZURDIA
Basically if the switch has one green and one yellow light, it means that the switch is stuck in boot mode.
1-Please try to disconnect from the Power outlet the ICX-7150 and reconnect it.
If this step doesn't work, we need to perform a software recovery.
01-12-2023 11:00 PM
I tried all the steps, and nothing has been working i was able to download the required apps to make it works and nothing. i tried the recovery but it always gets stuck on the putty 3 minutes in. also tried to the hard reset but yet i don't get it to communicate. i have been at it for 4 hours and no luck ,i have use all the ruckus videos and it do not want to work. any other ideas? i followed the steps 1 by one what else could it be?
