Showing results forย
Search instead forย
Did you mean:ย
No network connection when connected to Access points. R320 access points with ICX7150 switch.
bjrenna
We moved into a previously owned Lennar home. The system was setup by previous owner. ISP tech came out to turn on the internet, but didn't reset the access points. We have internet by connecting to the Blast router. I factory reset both access points (unplugged one, and reset the master). I am able to create a new SSID and complete the setup, but as soon as it is completed, there is no network connection. Therefore, I can't login with the AP IP address, can't configure settings, can't update firmware.
I've tried, reseting the modem, router and switch. I've tried factory resetting the other AP first, to see if one of the APs is faulty, but they both have the same issue. I've moved the ethernet cables to different ports on the switch. Ive tried connecting the switch directly to the modem. The 2.4 and 5G lights are on, and turn green when connected to a device. The power and CLT lights are green.
1 ACCEPTED SOLUTION
Hi @bjrenna
This issue is because your switch is running on the Routing code (SPR). The Switch should run on the Switching code (SPS) to avoid these issues for Lennar home users. Due to a power outage/power spike, the Switch boots up on the other partition which may be running on a โ€˜Routing Codeโ€™ results in causing this issue.
As I can see from the output you shared, your Switch is booted up on the secondary partition which is running on Routing code (SPR) as highlighted in the screenshot below.
copy flash flash secondary
NOTE: Please feel free to mark the post as ACCEPTED SOLUTIONS, if your issue gets resolved.
13 REPLIES 13
Imran_ruckus
Community Manager
Community Manager
Hi @bjrenna
Hope you are doing well!!!
As per the case description, I could understand that your RUCKUS setup is not working, and Access Points do not have internet access.
1. Was this working before? If it worked before, was there any power outage before you started facing this issue?
2. On your switch while it's plugged into the outlet, do you see any lights on? (Amber or green) Please let us know which lights are on. (Please refer to the below picture and share a picture of the same, showing the light status and the FULL Switch panel cable connections to the Switch ports)
3. May I know how many Access Points are connected to the Switch? Could you please let me know the light status on the Access Points? Any of these lights are on (Please refer to the below picture and share a picture of the same)
1. I have no idea if it has ever worked. We moved into a pre-owned home and have only ever used the main router for internet. I factory reset both APs in order to configure a new SSID and have never had it work.
2. All lights are green on the switch. If you toggle over to USB the USB light is amber. All other lights are green.
3. There are two access points in the house. I disconnected 1 in order to configure the other - creating the master AP. Ive tried the reset process with each AP as the master. Neither is successful.
I was finally able to configure the master IP, and connect frequency. Once connected I can connect to the APs IP address and login into unleashed, via the web. Its now telling me the ICX is disconnected and cannot be pinged. I believe this is the problem. How do I fix this? How do I get the ICX connected.
Configuration of wires, lights, and screen shots below:IMG_2394.jpegIMG_2396.jpegIMG_2397.jpegIMG_2399.jpegIMG_2395.jpegScreen Shot 2023-08-06 at 2.17.26 PM.png
Hi @bjrenna
We will check some configurations on the Switch, please follow the below steps to check the same.
1. To check this issue, we must identify the โ€˜currentโ€™ IP address assigned by your local router to the switch ICX-7150-C12P
How to find my Ruckus โ€œDevices IP addressโ€ using free applications:
2. Once we identify the IP address of the switch proceed to access remotely to the device โ€œCommand Lineโ€
ICX7150-C12 Router> OR
ICX7150-C12 Switch>
show version
show flash
I can't connected to the host because the "host is down". See screenshot below
This is a bit above my head. Is there someone I can call that can walk me through this?
