No STAT light on ICX-7150-C12P
mciccia777
Hello Team,
My 2 R510 don't have power, and I followed the below and I completed the CLI process and turned all Admin State, however the column beside it Oper State half of them say off and the other denied. Still no power from the PoE ports behind the switch. Also, behind the switch to the left of the PoE's there is a rectangular cube with the STATUS button and all the lights Stat, Spd, ID, USB, PoE are off. I need your assistance please and thank you!
NO Power on Access Points and ICX-7150-C12P Switch with GREEN lights on SYST & PWR and PoE disabled
6 REPLIES 6
Imran_ruckus
Hi @mciccia777
Based on the information provided, it appears that you are encountering issues with the RUCKUS ICX-7150-C12P Switch.
As you can access the CLI, please execute the following commands and provide the outputs:
   show version
   show flash
   show inline power
   show inline power detail
   show interface brief
Please share the command outputs or screenshots if you encounter any issues or errors during these steps.
Hello Team!
Attached are all the photos, thank you for your help and look forward to hearing back from you.
Best!
Mario
1_enable.png2_show version.png3_show flash.png4_show inline power.png5_show inline power detail.png6_show interface brief.png
Hi @mciccia777
Please enter the below commands and enable to PoE on the Switch ports.
Switch>enable
Switch#configure terminal
Switch(config-mif-1/1/1-1/1/12)#no inline power (please wait till the process gets complete)
Switch(config-mif-1/1/1-1/1/12)#inline power (please wait till the process gets complete and check)
Additionally, we suggest you upgrade your RUCKUS ICX-7150-C12P Switch, since it is on an older 08061a non-UFI version as I see from the screenshots you shared. Please refer to the below RUCKUS Lennar Knowledge Base self-help article on how to upgrade your Switch to the recommended version.
Please let me know if you are stuck at any point during the upgrade process.
Hi Imran,
I did exactly as you requested (except the upgrade) and I still don't see any power on the PoE.. Why? Also, it won't let give me the option to add pictures? Please help, this is very frustrating.. Thank you
