12-13-2022 04:04 PM
The power went out due to a storm at my home. Once the power came on the WAP had no lights on it. The brain for the WAP has power and a green and a yellow light on it. Can someone tell me what the issue maybe and how to fix it? thank you
12-14-2022 04:05 AM
Hi @amishandami
Basically, due the power outage/ power spike the switch went to a state that we called (boot-mode) that is not able to boot up properly.
That does not mean is broken or need to be replace 'in some cases'
1-Please try to disconnect from the Power outlet the ICX-7150 and reconnected.
If that does not make any difference, we need to perform a software recovery since it can be that the image flash is corrupted so in basic words the unit is not able to boot up properly and need re-install the image to boot up properly.
3-We need to access (physical) using one of the cables to the ICX-7150C12P mentioned on the below guide:
How to console in the ICX-7150-12cp
Once we are there, we can try to boot up the unit using the following commands:
Boot_primary or Boot_secondary
If that step does not work Software recovery needs to be applied
Here is the guide:
Best Regards
Fernando Vasquez
12-17-2022 08:39 AM
Hi thanks for all this information. I tried all the methods you suggested and I had no luck. I asked a local company to come check the ruckus console and they have told me the piece is fried or broken. I have only had it for about 1.5yr and I was hoping to have a case opened to see if this can be replaced via warranty. Please help my house is wired through ruckus and wap access and we have no internet due to this issue
12-20-2022 01:16 PM
12-21-2022 07:10 AM
Hi @amishandami
Please provided us a picture/ photo when you are trying to access console with the console cables on switch ICX-7150 - C12P and PC connected.
What error were you getting when trying to access the console, you can send it here:
Best Regards
Fernando Vasquez
