03-16-2023 08:48 AM
Hello, in the past 2 years, the Ruckus switch has failed 3 times (all 3 in the past 7 months) it is currently out again, and I am unable to reset it. The model no. is ICX7150-C12P. I have tried resetting it. Frustrating as this keeps failing.
Thanks, Gopal
03-16-2023 10:44 AM
I will do it, but this is the 3rd time I have to do this tedious process to get it to run again, in the last 7 months, so obviously something is wrong with the switch.
03-16-2023 11:18 AM
Hi @rama9998
As per the information you have shared, if the switch has green and amber light it means that the switch is stuck in boot mode.
It is a software related issue so we don't need to replace the switch.
For detailed understanding of the issue please share the screenshot of the error you are getting while performing the steps.
03-16-2023 07:07 PM
I tried resetting to factory default. all status lights keep blinking forever. I am not able to do the software recovery since i am unable to find out the COM# as windows says driver is not installed for network adapter.
03-16-2023 07:09 PM
I am unable to locate port under network adapter as per your instructions
03-16-2023 07:16 PM
I notice that the blinking lights have gone, Status is green, SYST is green and all the 3 ports are blinking. Now i have a different problem - I tried to login through the unleashed app. Unleashed home, Manage Network, login as admin and add my password, I am getting a "Unable to reach Unleashed Network" error. Can you please help?
