01-02-2023 09:49 AM
a month ago, wifi was lost.
i am using att now but not reliable.
how can I get my ruckus working again? i have rebooted the router and did not work
01-02-2023 01:52 PM
Hi @J_R_K
Only one Access Point will have the CTL light on, because that will be the master.
Yarenis Hernández.
Technical Support Engineer | L2 TAC Wired | Lennar Home Community
01-02-2023 12:57 PM
i got into my dashboard suing the IP address found using the advnaced IP scanner
it shows the Internet is connected; that is good
it shows 1 ethernet port enabled and the other with a red x (is that the issue)
got the IP address, gatway and DNS info.
when i click on wifi network, it says 1 wifi network whcih is Cyborg DH (which is correct0
but i don;t see where the SSID needs to get enabled and how to be fure 2 g and 5 g are enabled.
01-02-2023 12:58 PM
this is waht i see when i select eidt wifi
01-02-2023 01:06 PM
i was able to add a new wifi network.
the 2g and 5 g lights are yellow
why won't my old one come back on line?
01-02-2023 01:45 PM
Hi @J_R_K
Are you able to see the SSID/Wi-Fi Signals, because the yellow color just means is enable, but there are no clients connected using that signal, will change to green as soon you connect your devices(phone, computer, smart devices so on)
Yarenis Hernández.
01-02-2023 01:45 PM
i got one of my access points working.
the other one has the CTl as OFF. how can i get that working again
