09-04-2024 08:58 AM
Sorry for duplication - this was posted in Community forum previously.
We would like to be connected with certified or capable technician who can come to the home to reset and set up for our use and enable us to continue to maintain connectivity using the system.
09-09-2024 06:05 AM
Hi @LC_4
Thank you.
09-09-2024 01:19 PM
Since you have indicated that you do not have a way to connect us with a technician, we will work with someone to assist us with the system.
09-09-2024 01:24 PM
Hi @LC_4
Let me try to help you step-by-step.
To better assist you, could you please provide the following information?
1. When your switch is connected to the outlet, do you observe any illuminated lights (amber or green)? Kindly describe which lights are visible. Additionally, please provide a photo showing the status of the lights and the full switch panel with cable connections to the switch ports.
2. Is your internet connection from the ISP stable and functioning? You can verify this by connecting to your local router's Wi-Fi or through an ethernet cable from the router to a laptop/PC.
3. How many access points are currently connected to the switch? Please describe the status of the lights on the access points. Similarly, include a photo showing the access points' light status.
Please help me with ALL above information and should you have any further questions or concerns, feel free to reach out.
09-12-2024 05:36 AM
Hi @LC_4
Help me with the requested queries from my last response to assist you step-by-step.
Thank you.
09-16-2024 05:52 AM
Hi @LC_4
Thank you.
