08-09-2025 08:54 PM
I live in a Lennar home that came with a Ruckus ICX 7150-C12P switch and two Ruckus APs. I’m having trouble getting my network working again after trying to set up the second AP.
Current situation:
AP #1: Shows as Configure.Me-XXXXXX. I can connect to it and access the Unleashed setup page, but it says Internet: Disconnected, Ethernet: X, DNS: Unreachable. It does have an IP and Gateway, but no actual internet connectivity.
AP #2: Shows as Recover.Me-XXXXXX, which I understand means it is in recovery mode.
ICX 7150 switch is connected to my ISP router via the orange Ethernet cable, AP cables are in PoE ports. I tried moving the uplink cable to port 1/1/1 and rebooted both switch and APs, but still no internet.
I have already factory reset the Configure.Me AP and gone through the setup wizard.
What I’ve tried so far:
Factory reset AP #1 and created a new Unleashed network.
Reconnected cables with uplink from router to ICX uplink port (port 1/1/1).
Rebooted switch and AP multiple times.
Checked IP/DNS settings in Unleashed (set to DHCP).
What I need help with:
Why is my Configure.Me AP getting IP/Gateway but failing Ethernet/DNS checks?
How can I properly configure my ICX 7150 ports for uplink and AP connections?
Steps to recover the Recover.Me AP so it can join the network.
Any guidance, example configs, or troubleshooting steps would be greatly appreciated!
Thank you in advance.
08-18-2025 08:27 AM
Hello @zsl666 ,
08-20-2025 07:39 AM
Hi @zsl666 ,
Thank you.
08-20-2025 09:38 AM
Hi
Update on this: First AP working, 2nd AP showing as configure me. I have an issue to set up this one. It's very hard for me to connect to that configure.me.**** internet. I will try again when I get home tonight, and keep you updated.
08-20-2025 09:46 AM
Hello @zsl666 ,
We will await for your response and please keep us updated.
08-22-2025 07:21 AM
Hello @zsl666 ,
