My rukus wireless is not working
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
11-01-2022 09:54 AM
My rukus wireless is not working for past couple of weeks and would need urgent help
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-01-2022 08:51 PM
I tried running the IP scanner and was able to get the IP details. However, I am not able to ssh/telnet this IP. I am getting connection cannot be open error message.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-02-2022 09:22 AM
Can you please advise how to proceed?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-02-2022 09:51 AM - edited 11-02-2022 09:54 AM
Hi @sumeshp
If telnet access/ssh access is not working sometimes a hard reboot ( disconnect and connect the switch from the power outlet ) works but if that does not work, we need to access via console.
How to console in the ICX-7150-12c using a Windows Machine
Once you are log in you can follow one of these guides:
How to Fix Routing code issues on Lennar Home users
Best Regards
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-03-2022 06:59 AM
I got the IP Address using the IP scanner tool and trying to login using putty (port 22?). this looks like the user/pswd is not working. I tried the user provided in the link and also the tried the login that I use to login the mobile app. both are not working. Can you please advise?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-03-2022 07:18 AM - edited 11-03-2022 07:19 AM
Hi @sumeshp
Have you tried to use Telnet option ?
Most of the times should work the default password
username: super password: sp-admin
or username : admin password Lennar / username: admin password: Ruckus1
If that does not work we need to have Console access for sure.
Best Regards
Fernando Vasquez
