My Ruckus wireless router seems to have stopped connecting to any website - Reset etc doesn't work
sramakrishna26
My Ruckus wireless router seems to have stopped connecting to any website - Reset etc doesn't work. I put the device off for 5 mins, didn't help. I hit the reset button, didn't help. The verizon modem connects to the internet just fine - all the problem is at the Ruckus router.
1 ACCEPTED SOLUTION
Hi @sramakrishna26
Greetings of the day!!!
Thank you for the response and update.
Great!!! Good to know that the issue is now fixed.
Have a great day ahead!!!
Lennar Home Community.
25 REPLIES 25
and when I try the -keygen -R  option, it says
Cannot stat /home/mobaxterm/.ssh/known_hosts: No such file or directory
Hi @sramakrishna26
Could you please try to use the Putty application and try to SSH? Please share the screenshot if you are getting any errors.
Same - connection refused
It says PuTTY Fatal Error
Can I just do a hard reset? Why do I have to do these complex things ?  I am fine re-creating all the settings for my WiFi network. How come this device misbehaves when one has just a power outage??
Type a product name
