03-25-2026
07:17 AM
- last edited on
03-25-2026
09:03 AM
by
Imran_ruckus
My ICX-7150 C12P switch is dead. No lights.
Hello Support Team,I own a Ruckus ICX 7150-C12P and a WAP through Lennar. My switch is not powering on at all. When I plug it in, the amber light flashes briefly, then the unit shuts off completely, and no lights remain on. There have been no power
Remove power from the switch.
Press and hold the reset button while applying power to the switch.
Release the reset button after all of the system LEDs are not turning on
SN:- ***********
Product Name: 12-PRT POE+ COMP 2X1G SFP+
Product Family: ICX Switches Product Code Part: C12P
Warranty Expires: January 15, 2031
Edit: some information removed for security reasons - admin
03-27-2026 05:19 AM
The green LEDs on the PWR and SYST indicators represent normal device behavior.
Please proceed with connecting your devices and check if you are able to access the internet.
For detailed guidance on device connectivity and configuration, kindly refer to the RUCKUS Lennar Knowledge Base article below:
https://community.ruckuswireless.com/t5/RUCKUS-Lennar-Support-Knowledge/RUCKUS-Lennar-Home-devices-C...
If you need any assistance while following the steps, please feel free to reach out.
03-27-2026 09:18 AM
in all the 12 slots am getting yellow light .? internet is not connecting
03-27-2026 09:22 AM
i am seeing the yellow lights but its not connecting
03-27-2026 09:24 AM
After Factory Reset, I am seeing yellow lights in the 12 slots
The internet is not connecting...?
03-27-2026 10:18 AM
Could you please describe the status of the lights on the access points. Similarly, include a photo showing the access points' light status.
Thank you again.
