Lennar woes - stuck in routing
Kevind
I have a ICX-7150 that’s stuck in routing mode and I need to get it into the switch code so I can upgrade it however I can’t serial connect to it and can’t locate an IP for the device. Any suggestions?
14 REPLIES 14
pinky_ruckus
Hello @Kevind ,
As per the case description, I understand that your RUCKUS setup is not working and not getting IP address.
  1. Was there any power outage before you started facing the issue?
  2. Please refer to the below picture and share a picture of the same, showing the light status and the FULL Switch panel cable connections to the Switch ports)
 here is the status of the system. The issue occurred after a power outage 2 years ago and I’ve lived with this ever since and finally getting to cleaning up Lennars mess.
Hello @Kevind ,
Thank you for the response and sharing the pictures.
From the response you shared, I understand that the status lights on the Switch is Amber and the PWR light is Green, which means that the Switch is stuck in a boot mode
Please follow the below RUCKUS Lennar Knowledge base self-help article which will help you to fix the issue when the Switch is in boot mode.
https://community.ruckuswireless.com/t5/RUCKUS-Lennar-Support-Knowledge/Fixing-RUCKUS-Switch-with-an...
Please follow the process as explained in the article and let me know if you have any queries in this regard.
I had to go through the second option and restore the entire image on the system, now that I've done that the system is up but there is no access to it. I've tried the super and sp-admin combo but no luck, what would the credentials be set to?
Hello @Kevind ,
From the response you shared, I see that you have performed reset and software recovery.
Switch default credentials will be as mentioned below.
Username: super
Password: sp-admin
If the above credentials don’t work, you can try the default credential combinations below as well.
These usernames and passwords are key sensitive, please use capital letters where necessary.
