12-19-2025 06:21 AM
I have been having issues with my Ruckus Wireless and it continuously drops connection. Have one ruckus wireless switch with 2 access points. Sometimes the AP ends up turning "Yellow" and post reboot it turns "green". Sometimes it needs 2-3 restarts to get it in to green from yellow.
Currently both Access Points are showing green , but the Ruckus wireless POE has one port which is "Green" and the other one is "Yellow". I opened up the browser link to the ruckus portal and its shows the yellow port as "Up with Warnings". Please help as I work from home and the internet connection is not stable
Regards
Roshan Bhandary
12-19-2025 11:46 AM
Hello @roshanbhandary ,
I understand that the version on the Switch is 08.0.90d.
We recommend transitioning to version 08.0.95g, identified as the stable version for Lennar Home users.
To facilitate this transition, we have recently introduced an upgrade tool tailored to ensure a seamless process. Utilizing this tool is straightforward: users simply need to input the IP Address, Username, and password associated with the Switch into the software interface.
1. For your convenience, please find the necessary resources below:
2. Access the Upgrade Software User Manual: Link: Upgrade Tool User Guide for Lennar SmartHome users
Please note: For now the tool works only on 08080f and versions between 08095g.
We highly value your input and would greatly appreciate your feedback on our upgrade tool. Your insights are instrumental in our ongoing efforts to enhance user experience and ensure the tool meets your needs effectively. Please take a moment to share your thoughts, suggestions, or any issues you encountered while using the tool. Your feedback is invaluable to us and will guide us in further improving the tool for all our users. Thank you for your time and contribution.
Should you require any assistance throughout the process, please do not hesitate to reach out. Your satisfaction is our priority, and we are here to support you every step of the way.
12-19-2025 01:47 PM
I successfully upgraded the driver to 08095g and everything came up fine. Please consider this thread as closed.
12-19-2025 01:48 PM
We are glad to know that the issue is resolved, and the Switch is upgraded to 08095g version.
Please feel free to contact us if there are any issues in this regard in future.
01-12-2026 01:20 PM
It worked for sometime post the upgrade, but again one of the switch port light has turned yellow can the internet speed is wonky.
It worked fine for some days and not back at the same issue. Please help
Regards
Roshan Bhandary
01-12-2026 01:37 PM
As per the case description, I understand that your RUCKUS setup is not working and having slow speed and intermittent issues.
1. Was there any power outage before you started facing the issue?
2. Please refer to the below picture and share a picture of the same, showing the light status and the FULL Switch panel cable connections to the Switch ports)
3. May I know how many Access Points are connected to the Switch? Could you please let me know the light status on the Access Points? Any of these lights are on (Please refer to the below picture and share a picture of the same)
01-12-2026 02:07 PM
01-13-2026 05:12 AM
Hi @roshanbhandary
Before we can help, we need to check few configurations on the Switch
To check this, we must identify the ‘current’ IP address assigned by your local router to the switch ICX-7150-C12P
ICX7150-C12 Router> OR
ICX7150-C12 Switch>
show version
show flash
