Lennar Ruckus Power Outage Need Help ASAP Work from home
Janele84
  • Hiii can someone please assist. We had a power outage and my tv, computer and security system is connected to the ruckus. Work from home and im non technical and need assistance with resetting please. Thanks
1 ACCEPTED SOLUTION
Hi @Janele84
As I can see from the picture you shared, there are lights on PWR and SYST, if there is an amber/orange light on the "SYST" and a green light on the "PWR" on the Switch (as it is in the below picture). Meaning the Switch is stuck in the boot mode.
Basically, due to the power outage/ power spike, the switch went to a state that we call ‘boot mode’ that is not able to boot up properly.
First, we will try to reset the Switch as described below:
  • Remove power from the switch.
  • Press and hold the Reset button while applying power to the switch.
  • After all the system LEDs flash amber, release the Reset button.
IF RESET IS NOT WORKING, PLEASE TRY TO RESET YOUR SWITCH MULTIPLE TIMES (Like 10-15 times) AS DESCRIBED ABOVE.
7 REPLIES 7
Hi @Janele84
Thank you. It came back on.
Hi @Janele84
Great!!! Good to know that the issue is now resolved.
Have a great day ahead!!!
