Lennar ICX7150-C12 Switch unable to reset after power outage SYST light orange
Ch823
My switch is not sending power to any of my equipment. The SYST light is orange and I have read through the forums and tried factory resetting with no luck. I am not to familiar with Putty and have also tried those steps looking through the forums. Is there any other way I can get help with this?
Thank you
1 ACCEPTED SOLUTION
Hi @Ch823
As you have performed the software recovery to the Switch which is already of 08.0.90 or later. However, you could Upgrade your Switch to the latest version.
Could you please share a full screenshot showing the information?
23 REPLIES 23
Imran_ruckus
Community Manager
Community Manager
Hi @Ch823
Hope you are doing well!!!
As per the case description, I understand that your RUCKUS setup is not working, after a power outage with no transmission of Power through it and there is an Amber light on SYST.
As you mentioned there is an Amber light on SYST, if there is an amber/orange light on the "SYST" and a green light on the "PWR" on the Switch (as it is in the below picture). Meaning the Switch is stuck in the boot mode.
Basically, due to the power outage/ power spike, the switch went to a state that we call ‘boot mode’ that is not able to boot up properly. This is the reason your RUCKUS ICX-7150-C12P Switch is unable to transmit power (PoE- Power over Ethernet) to the Access Points or on its ports.
As you mentioned that you tried resetting, once again we will try to reset the Switch as described below:
1. Please try to disconnect the from the Power outlet the ICX-7150 and reconnect.
  • Remove power from the switch.
  • Press and hold the Reset button while applying power to the switch.
  • After all the system LEDs flash amber, release the Reset button.
IF THE RESET IS NOT WORKING, PLEASE TRY TO RESET YOUR SWITCH MULTIPLE TIMES (Like 10-15 times) AS DESCRIBED ABOVE. As we have seen it working sometimes after trying multiple times in many cases. If the reset with a paperclip works, the SYST and PWR lights should turn GREEN.
Apologies IF RESET DOESN’T WORK software recovery using Putty is the only option: Please follow the below steps.
If the reset does not make any difference, we need to perform a software recovery since it can be that the image flash is corrupted in basic words the unit is not able to boot up properly and needs to re-install the image to boot up properly.
Please note, we must use ethernet cable (both ends RJ45 plugs) and USB to type C cable together as described in steps 2 & 3 in the guide link.
I get to here then I get stuck and get get past this part.
Hi @Ch823
Please close the Putty and restart it once again. You should only see ‘ICX7150-Boot>’. Once you complete the configurations as described in the guide you can process with the setenv commands and other steps.
This is what I got after completing all the steps. Syst light is still orange
