Lennar Home Ruckus ICX7150 routing code issue
bindihar
Unable to use the solutions provided in this community to get access to Ruckus console.  Please contact me to assist.
Bob
1 ACCEPTED SOLUTION
Hi @bindihar
Great!!! Good to know that the issue is now resolved.
Have a great weekend ahead!!!
9 REPLIES 9
Hi @bindihar
Please follow to the below screenshot and enable Telnet then try accessing the CLI:
Once you enable Telnet try to access CLI from the MAC terminal as described below. And share the output of the commands mentioned below in this post.
If you have a MAC device, please try the below process.
Example "open terminal":
Telnet: Example
nc 10.0.0.132 23 (Format is : nc <ip address of the switch> 23)
If you can access the Command line using Telnet should look like below prompt:
????telnet@ICX7150-12P Switch>
show version
show flash
Please share the output of the above commands or share the screenshots if stuck at any step or error (if any) and let me know if you have any queries in this regard.
bindihar
I got part way but maybe I am supposed to put in either a password or a router #????
Hi @bindihar
You have executed the command correctly. There is no need of adding anything.
As you know this issue is because your switch is running on the Routing code (SPR). The Switch should run on the Switching code (SPS) to avoid these issues for Lennar home users. Due to a power outage/power spike, the Switch boots up on the other partition which may be running on a ‘Routing Code’ results in causing this issue.
As I can see from the output you shared, your Switch is booted up on the secondary partition which is running on Routing code (SPR) as highlighted in the screenshot below.
copy flash flash secondary
Example below:
VIDEO LINK AS REFERENCEhttps://www.youtube.com/watch?v=Eem1IBgYaWc
????telnet@ICX7150-C12-Router>enable (hit enter to accept the command)
????telnet@ICX7150-C12-Routerr#copy flash flash secondary (hit enter to accept the command and wait: until the flash finished)
????telnet@ICX7150-C12-Router#boot system flash secondary yes (hit enter to accept the command: the switch will reboot)
Thanks so much Imran......that worked...got it switched to the right partition.
Bob
Hi @bindihar
