03-14-2024 02:35 PM
Unable to use the solutions provided in this community to get access to Ruckus console. Please contact me to assist.
Bob
03-15-2024 12:20 PM
Hi @bindihar
Great!!! Good to know that the issue is now resolved.
Have a great weekend ahead!!!
03-15-2024 05:36 AM
Hi @bindihar
As per the case description, I understand that your RUCKUS ICX-7150-C12P Switch has Routing code issue, and you are trying to get console access to the Switch.
Could you please share a screenshot of the error you are getting when trying to get console access?
For routing code issue troubleshooting steps, please refer to the below RUCKUS Lennar Knowledge base self-help article.
03-15-2024 08:50 AM
Thanks for the reply Imran!! Here is the screen shot.
03-15-2024 10:45 AM
Hi @bindihar
Could you please try to access the Switch IP address on a bowser and try to login?
If you don’t see above dashboard from the IP address you used, please check the other IP Addresses from the IP scan results, by the name of Ruckus Wireless or Brocade Communications to confirm the IP address of the Switch.
03-15-2024 11:08 AM
Thanks @imran_ruckus. Yes, I was able to login and see the screen as you have sent in the screen shot. Now what do I do?
