05-16-2024 11:09 AM
For a few months now the R510s in my house have been barely able to support online activity. We have to connect to our modem/router in the basement to really get any internet and on the top floor of the home, that can be problematic. After much finagling, I cannot seem to figure out what is causing this issue. I've tried reseting the system and even signing into the Unleashed App (which I am unable to do). My thoughts are that they need to be updated or master reset somehow, but I'm not really sure where to start with either of those. Has anyone had any similar issues or is there someone who can point me in the right direction for fixing this? Thank you!
06-19-2024 10:11 AM
Hello @crwilson
Thank you for your response and for sharing the information.
I have verified that the status lights of both the RUCKUS Access Points and the RUCKUS ICX-7150-C12P Switch indicate normal operation, with the cables correctly connected to the switch ports.
At this stage, I recommend performing a physical factory reset on your Access Points and configuring them with a new Wi-Fi WLAN/SSID. You can find detailed instructions for the factory reset process in the RUCKUS Lennar Knowledge Base self-help article linked below:
Please follow the steps outlined in the article. Should you require any assistance during this process, feel free to reach out.
06-21-2024 01:20 PM
Hi @crwilson
Your prompt response would be greatly appreciated.
Thank you for your attention to this matter.
06-24-2024 01:26 PM
Hi @crwilson
06-26-2024 12:31 PM
Hi @crwilson
Please note, this is a last follow-up, if we do not receive a response from you within 24 hours from the timestamp of this message, your case will proceed to closure.
05-20-2024 02:04 PM
Hi @crwilson
Hope you are doing well.
Could you please provide an update on the status of the issue to proceed further?
Thank you.
