Issues with my R510s
crwilson
For a few months now the R510s in my house have been barely able to support online activity.  We have to connect to our modem/router in the basement to really get any internet and on the top floor of the home, that can be problematic.  After much finagling, I cannot seem to figure out what is causing this issue.  I've tried reseting the system and even signing into the Unleashed App (which I am unable to do).  My thoughts are that they need to be updated or master reset somehow, but I'm not really sure where to start with either of those.  Has anyone had any similar issues or is there someone who can point me in the right direction for fixing this?  Thank you!
11 REPLIES 11
Imran_ruckus
Community Manager
Community Manager
Hi @crwilson
As per the case description, I understand that your RUCKUS setup is not working, with Internet connectivity issues.
1. If it worked before, was there any power outage before you started facing this issue?
2. On your switch while it's plugged into the outlet, do you see any lights on? (Amber or green) Please let us know which lights are on. (Please refer to the below picture and share a picture of the same, showing the light status and the FULL Switch panel cable connections to the Switch ports)
3. Is your Internet Connection from the Internet Service Provider (ISP) stable and working? (You could check this by connecting to your local router Wi-Fi or from an ethernet cable from the Router to a laptop/PC).
4. May I know how many R510 Access Points are connected to the Switch? Could you please let me know the light status on the Access Points? Any of these lights are on (Please refer to the below picture and share a picture of the same)
Please let me know the answers to ALL the above queries and let me know if you have any queries in this regard.
Sorry on the long reply.  Was sick. Answers below:
1.) No power outage.
2.) Green lights.  STAT, SYST, PWR are all on.  As are all the ethernet ports that are plugged in.
3.) Yes, the ISP is stable.
4.) Two R510 Access Points are connected to the switch:
     Main floor unit has 5G, 2.4G, CTL and PWR illuminated.  AIR is not.
     Upper floor unit has 5G, 2.4G, and PWR illuminated.  CTL & AIR are not.
Hello @crwilson
Thank you for providing the information. However, the picture of the RUCKUS ICX-7150-C12P Switch you shared appears to be partially visible. Could you please refer to the attached picture and provide a full view showing all cable connections to the switch ports?
Please feel free to reach out if you have any questions regarding this matter.
Thank you for your understanding and patience.
