Showing results forย
Search instead forย
Did you mean:ย
Issues with R510 APs
ryanb2
I moved into a Lennar home where the previous homeowners did not reset or erase their configuration.
The set up includes two APs (R510s, one on first floor and one on second floor) and an ICX 7850 12-port switch. The switch is currently not connected to the router for up and out connectivity. I factory reset both routers a few times. Once when they were both connected to PoE ports and a second time for each one while the other that was not getting reset was disconnected to power. When I did this, I didnโ€™t get the โ€œConfigure-Meโ€ SSID option even after waiting 10-15 minutes for both.
On the master AP however, I got the โ€œRecover Meโ€ option. Past forums posts on here were not helpful with addressing the issue. Is there a default password I can use for this so I can console in and change settings?
Thank you!
1 ACCEPTED SOLUTION
Hi @ryanb2
We can reset the access points and create a new network from scratch for you to use.
1. Connect an ethernet cable between your ISP router and our Ruckus switch. (This step is essential to proceed with the following instructions.)
2. Ensure that the master access point displays solid green lights for PWR and CTL.
3. Follow the steps provided in the following link to reset and create a new Unleashed network.
> If you have multiple Access Points (APs) in your house, go to the Ruckus Switch (located in the panel) and disconnect the Ethernet cables from all Access Points, except the one you are going to work with.
Only keep one access point connected to the Ruckus switch throughout the entire process until the new network appears. Once you confirm that the created network is visible in your laptop's "network and internet settings" tab, you can proceed to connect the other access points one by one.
4. Once completed, connect the second access point, and it will automatically join the new network you have created.
Note: Ensure that ALL cables are connected to the 12 ports on the front panel, organized in 2 rows of 6 ports each.
Kind regards,
Sofia Gรคtjens
11 REPLIES 11
Sgatjens
Hi @ryanb2
3. Is your Internet Connection from the Internet Service Provider (ISP) stable and working? (You could check this by connecting to your local router Wi-Fi or from an ethernet cable from the Router to a laptop/PC).
Could you please check the link below and confirm that the setup you have is the correct one?
Kindly note that your internet service is expected to be provided by your ISP; our role is to assist in optimizing connectivity throughout your residence.
Kind regards,
Sofia Gรคtjens
โ€ƒ
โ€ƒ
โ€ƒ
โ€ƒ
Hey Sofia! Hope all is well with you too and thanks for reaching out.
To answer your questions:
1. Iโ€™m not entirely sure if the system worked for the previous homeowners. They had their own SSID configured using their family name, so I know they at least attempted to make them work. Weโ€™ve been using a Netgear router for WLAN but I wanted to see if I could get the APs to work a few days ago when I noticed the โ€œRecover Meโ€ SSID was the only option after physically resetting the routers. A power outage did not cause this issue.
2. See attached picture. Getting green status/system/power LEDs. I have the 2nd floor AP plugged into port 2, getting steady green LED. 1st floor AP is unplugged.
3. ISP connection is stable (Google Fiber with AT&T modem and TP-Link router). However, I donโ€™t have any Ethernet cabling running from router to Ruckus ICX-7150. Running WLAN off of TP link MLS.
4. See attached picture. Only the second floor AP is plugged in currently, which was previously the master AP. Itโ€™s receiving power, getting green solid CTL light and slow blinking green power light.
*note: when the 1st floor AP is plugged in and 2nd floor is not, the 1st floor AP gets alternating slow blinking green LEDs on power, CTL, and Air indicators.
Let me know if you need anything else.
V/r,
Ryan
And yes, based on the link you provided, that is how my home is set up.
Hi @ryanb2
Kind regards,
Sofia Gรคtjens
I plugged my TP Link router using Ethernet to the Ruckus switch (port 3) and then followed the reset instructions provided. However, Iโ€™m not seeing the โ€œConfigure.Me-<Last6MAC>โ€ option. The โ€œRecover.Meโ€ SSID is not there but the previous homeowner SSID is now showing. Would I have to reset it again to get the Configure.Me option and get rid of the previous homeowners network?
