07-24-2023 07:16 PM - edited 07-24-2023 07:20 PM
I have an icX router in my Lennar home. Every time the power goes out we have a connectivity issues. I also did a firmware upgrade but still have issues and you can see that. I also have we’re says the switch is disconnected.failed to ping
08-02-2023 08:09 AM
Hi @Wecovernc
This issue is because your switch is running on the Routing code (SPR). The Switch should run on the Switching code (SPS) to avoid these issues for Lennar home users. Due to a power outage/power spike, the Switch boots up on the other partition which may be running on a ‘Routing Code’ results in causing this issue.
As I can see from the output you shared, your Switch is booted up on the secondary partition which is running on Routing code (SPR) as highlighted in the below screenshot.
copy flash flash secondary
NOTE: Please feel free to mark this post as ACCEPTED SOLUTIONS, if your issues is resolved.
07-31-2023 02:54 PM
Hi @Wecovernc
As you are getting the Ruckus# prompt, it is of Unleashed Access Point IP Address. Please check the correct IP Address of the Switch from the IP Scan results.
Please check the other IP Addresses from the IP scan results, by the name of Ruckus Wireless or Brocade Communications to confirm the IP address of the Switch and access the CLI.
Thank you again for your patience and understanding
07-31-2023 02:57 PM
I know it is the correct IP of the switch because I was able to use Microsoft edge and that IP address and access the switch directly and get the homepage of the switch. However, when I try to get to it and putty, I’m getting where it’s asking me for the rukus number
07-31-2023 03:02 PM
Hi @Wecovernc
As you mentioned that, you are able to access the Switch GUI, Could you please help me with the information shown in the below screenshot?
07-31-2023 03:53 PM
Mine looks like this using Microsoft edge to log in.
07-31-2023 03:54 PM
Like this
