06-22-2023 12:34 PM
there were two rapid power outs yesterday and it knocked out my ICX7150. Upon reboot, it is no longer sending power over Ethernet. I tried rebooting multiple times. None of the Ethernet plugs are lighting up. When plugging in and booting Putty, I see that it is trying to load a partition and continually failing on a loop - it does not give me the opportunity to get in and enter any code to try to force it to boot a flash partition. It seems to be completely bricked
06-22-2023 01:29 PM
Hi @Austin
Hope you are doing well!!!
As per the case description, I could understand that your RUCKUS setup is not working, after brief power outages.
1. On your switch while it's plugged into the outlet, do you see any lights on? (Amber or green) Please let us know which lights are on. (Please refer to the below picture and share a picture of the same, showing the light status and the cable connections to the all Switch ports)
2. May I know how many Access Points are connected to the Switch? Could you please let me know the light status on the Access Points? Any of these lights are on (Please refer to the below picture and share a picture of the same)
06-22-2023 02:11 PM
There are three access points - none of them are lighting up. Syst and Power are lighting up. I cannot take a picture of it at the moment but did spend an hour staring at it last night and remember.
06-22-2023 02:25 PM
Hi @Austin
We may need to check the Switch ports PoE information from the CLI access. To check the same, please follow the below steps and help us with the output of the CLI commands mentioned in this post below.
1. To check this issue, we must identify the ‘current’ IP address assigned by your local router to the Switch ICX-7150-C12P
ICX7150-C12 Router> OR
ICX7150-C12 Switch>
show version
show inline power
show inline power detail
06-22-2023 02:41 PM
I was not able to find the IP address for it using that method. I instead connected directly into the unit with a USB-C cable. When I booted Putty, it did not give me the option to type. I powercycled the unit, and got this now:
It is not continuing past this line, and will not let me type. Previously, after the "stored in flash...." it would say "Failed!" and then output a lot of lines before trying again. This time it is hard stuck right here.
