11-11-2023 08:53 AM
The other day my ICX 7150 stopped supplying power to our wireless access points. We were able to test the ports and Internet is still flowing through, but power is not. We’ve reset the switch using the online troubleshooting advice both by powering it off and holding down the reset button and those options did not correct the situation. Can I get an RMA to return this device under warranty and get a new one?
11-14-2023 03:47 PM
Hi @MSellman
As per the light status of the RUCKUS ICX-7150-C12P Switch it seem to be in a normal status.
As I see from the picture you shared, seems like the ethernet cable which is coming from the ISP’s (Internet Service Provider’s) Router or Modem/Router combo or any other device is plugged into the wrong port on the Switch panel. It must be plugged into any 1 in-12 ports as shown in the below screenshot. Please unplug the ethernet cable and plug it into the correct port and also unplug and plug the Access Point’s ethernet cables from the Switch port and check if they get power. If required reboot (unplug and plug from the power outlet) your RUCKUS ICX-7150-C12P Switch and ISP Router once.
If the above steps don’t work, we may need to see some Switch configurations, please follow the below steps and help with the queries for the same.
Please follow to the below steps to access CLI and get the output of the below-mentioned commands.
ICX7150-C12 Router> OR
ICX7150-C12 Switch>
show version
show flash
show inline power
show interface brief
11-16-2023 06:48 AM
Hello - We've had our switch for 5.5 years now and the cables have always been plugged in the way I'm showing. It worked for 5.5 years until a few weeks ago so I doubt it's an issue with cable location. However, I did move the cables as you asked and still do not have power to the access points. I also reset the device per instructions and still no power. I am also unable to remotely access the command line. I've followed the steps in this link https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-remotely-access-to-IC... and was unable to access the Command line and still have no power to any access points.
11-16-2023 07:35 AM
Hi @MSellman
Could you please let me know the error you are getting when accessing the CLI? Please share a screenshot of the same.
11-16-2023 07:53 AM
Hi - I'm not receiving an error message as I'm unable to connect at all. The switch isn't sending any info to my computer at all, it's not showing any connection. The cli screen is blank.
11-16-2023 09:16 AM
Hi @MSellman
Could you please let me know if you are trying to access CLI using the Switch IP Address OR console access?
Please confirm.
