04-21-2023 02:30 PM
Hello, my managed switch ICX7150 failed again when there was a power drop for approximately 1 min. I am tired of this failing again every time there is a power blip. So I am replacing it with a non-managed POE+ switch from a different brand.
I still have my 2 APs from Ruckus - they are the R510s. Both of them are working (power is green, 5Ghz is green etc.etc.) But I need to manage them. Is there an app i can use? I have the unleashed app, but unable to access the APs through that app since it is not showing "Configure.Me-xxxx" in my wifi ssid options.
I guess it ie because it is not factory install - can someone please help me figure out a way to help manage these R510 APs ?
04-24-2023 08:34 AM
Hi @wmckennaiv
Hope you are doing well
As this case is raised by @rama9998
To avoid confusion with posts, you can create your own post with the problem you're facing and a detailed description of the network issue and what you've done so that we can guide you properly.
Lennar Home Community.
04-22-2023 10:10 AM
Lennar told me I could request a new switch since the software is faulty and I have a lifetime warranty on this not is not my job to fix your product. Please reach out to me so you can process a new switch for me.
