05-24-2023 09:06 AM
Hi, I have a ICX7150-C12P switch serial #FEK3852Q196 that all of the sudden does not seem provide power to any of the PoE ports, so the two access points we have connected to the PoE ports do not turn on.
I tried power cycle and reset button a few times, but still same issue. The status lights on the switch seem to turn on correctly. However, the lights/indicators on the PoE ports and access points never turn on.
Please advise,
Arturo
05-26-2023 08:15 AM
Hi @Arturo
As you mentioned and I can see from the screenshot you shared, there are lights on PWR and SYST, If there is an amber/orange light on the "SYST" and a green light on the "PWR" on the Switch (as it is in the below picture). Meaning the Switch is stuck in the boot mode.
Basically, due to the power outage/ power spike, the switch went to a state that we call ‘boot mode’ that is not able to boot up properly.
First, we will try to reset the Switch as described below:
IF RESET IS NOT WORKING, PLEASE TRY TO RESET YOUR SWITCH MULTIPLE TIMES AS DESCRIBED ABOVE.
05-26-2023 12:30 PM
Hi Imran, I tried the reset procedure several times as per your advise. However, all system lights just keep blinking amber, non-stop, after waiting several minutes, even I waited a few hours and still all lights blinking amber. I will try the software recovery process and keep you posted,
Thanks,
Arturo
05-26-2023 01:05 PM
Hi @Arturo
Thank you for the response and update.
Sure, please go ahead and perform the software recovery process and please let me know if you get stuck at any point in the software recovery process.
05-26-2023 01:06 PM
Hi Imran, I've tried the software recovery process, but when trying to console with the switch, the system is just unresponsive. The PuTTY session is just totally unresponsive. Nothing displays in my telnet session when trying to establish serial connection, I just get a black screen,
Please advise,
Arturo
05-26-2023 01:09 PM
Make sure you are using the correct IP address.
