ICX Switch Connectivity Issue after Power Outage
wmckennaiv
Let me start by saying that I know this question has been asked multiple times and I have read through all of the forums throughly and spent hours trying to rectify this problem with no success.  Please explain this to me as if I am the most tech illiterate person on the planet.
1.) When I log into the Dashboard this is what I see.  I have inputed what I believe to be the proper IP address, based on the IP Address given in my AT&T Smart Home Manager.  This does not work.  I am stumped as to what else to do.
7 REPLIES 7
Chandini
RUCKUS Team Member
Hi Wmckennaiv
Ack and Noted. Thanks for reverting back.
Please refer the same link in the previous post for console access to switch . In the last you have a video and instructions for a Mac iOS system solution .
wmckennaiv
The password and username are not working for access. I will need a replacement switch. I have followed every step throughly. 10 hours of logged time on this issue. Please let me know how to process my lifetime warranty and replacement ASAP. THANK YOU.
Hi @wmckennaiv
Hope you are doing well!!!
Apologies, as this is a configuration issue, that can be resolved. Warranty is only covered for the Hardware issues.
Please try to reboot your Switch and check the Unleashed dashboard. Sometimes the Switch may require a hard reboot (disconnect and connect the switch from the power outlet). Also, Unplug and plug the ethernet cables from the Switch ports panel and plug them back again.
