04-30-2023 07:37 PM
My unit will flash lights when plugged in and then no other activity (green lights on front or ability to access via app).
05-02-2023 08:38 AM
I still receive the same response as the time lapse images. Everything flashes after plugging in and then there are no LEDs illuminated.
05-02-2023 10:55 AM
Hi @Djestes24
Please let us know whether you have tried the factory reset or not. If yes please follow the below steps to solve the issue.
If the factory reset step doesn't work, we need to perform a software recovery.
05-02-2023 11:00 AM
Yes I did try the factory reset. The results were the unit flickered lights and then nothing else occurred.
the link to perform software recovery takes me to a “url not found” error screen.
05-02-2023 11:06 AM
Hi @Djestes24
Thanks for your response .
Please follow the below link to perform software recovery process.
05-02-2023 03:17 PM
I cannot complete the software as the unit does not power on so I cannot establish a connection. While working through the software instructions I cannot get past the putty piece as it times out trying to connect.
