06-27-2023 01:35 PM
I have an ICX 7150 running on the latest SPR UFI code. I am trying to upgrade to the Switch firmware but I am getting an error writing to flash. I have tried from the Web CLI and the console through SSH. Each time, it copies and fails at 25% when writing. I have tried a new download and after several reboots, but no go. I have saved off the support files from the web upgrade.
07-11-2023 05:44 PM
Ok, i think I found the issue. I didn't need to run the Mount Disk0 command because the drive was already mounted. I am trying to flash the firmware now.
07-11-2023 05:46 PM
I attempted the upgrade via USB again and it failed as it previously did.
ICX7150-C12 Router#copy disk flash SPS08095gufi.bin primary
Parameter Validation Successful
Image Download started
Image Download Done
Image Validation Started
Tuning CFS scheduler parameters...
Compressing Console file
Copying fitrace errorlog file to flash
CORE_PATTERN:PID=2113 !usr!bin!img_flash_packages UID=0 GID=0 sig=11
Wed May 3 00:37:23 UTC 2023: Dumping core file to /tmp.gz, this will take couple of minutes ...
Image write to flash failed
Wed May 3 00:37:26 UTC 2023: Core file collected as /tmp.gz, processing the core file ...
Copy Operation Failed
ICX7150-C12 Router#Wed May 3 00:37:27 UTC 2023: Calculating checksum: core_2113_img_flash_packages-1_2023-05-03_00-37-27.gz
Wed May 3 00:37:27 UTC 2023: Checking integrity of core_2113_img_flash_packages-1_2023-05-03_00-37-27.gz
Wed May 3 00:37:27 UTC 2023: Moving core_2113_img_flash_packages-1_2023-05-03_00-37-27.gz of size 56 KB to flash, with available space of 833428 KB...
Wed May 3 00:37:42 UTC 2023: Core saved as /fast_iron/cores/core_2113_img_flash_packages-1_2023-05-03_00-37-27.gz.
Moving system log files to persistent memory
Copying SZ log files to persistent memory..
Done.
Core collection and system log collection completed, Switch will not reboot for img_flash_packages crash
07-12-2023 07:48 AM
I am awaiting on next steps!
07-12-2023 02:40 PM
Hi @diver19743
Please try software recovery on your ICX-7150-C12P Switch as described below.
We need to perform a software recovery since it can be that the image flash is corrupted in basic words the unit is not able to boot up properly and need re-install the image to boot up properly.
Please share the screenshots if stuck at any step or error (if any) and let me know if you have any queries in this regard.
07-12-2023 03:25 PM - edited 07-12-2023 03:32 PM
