ICX 7150-C12P ethernet switch is not powering on.
bjrobinson08
I have a Lennar home. Our Ethernet switch is not working properly. I have tested the outlet and it has 120VAC power. The unit does not have any lights on it. The status button does not provide any help, again no lights. When I unplug and plug the unit back in, it lights up briefly for a moment. It seems that the switch cannot hold power.
Please advise.
Model: ICX 7150-C12P
S/N: ***********
9 REPLIES 9
Imran_ruckus
Community Manager
Community Manager
Hi @bjrobinson08
Based on the information provided, it appears that you need assistance in setting up RUCKUS devices in your Lennar Home.
I recommend attempting a physical factory reset multiple times, as detailed in the RUCKUS Lennar Knowledge Base self-help article and video available at the link below:
https://community.ruckuswireless.com/t5/RUCKUS-Lennar-Support-Knowledge/Process-for-performing-a-phy...
Please let me know the outcome once you’ve tried this.
Thank you once again for your patience.
bjrobinson08
I tried to reset the ethernet switch and I have the same results. I also tested the outlet and it is working properly. See attached picture. Ruckus-Switch.jpg
Hi @bjrobinson08
I cannot share a video. I can take as many photos as you need. The switch is clearly not working no status lights on at all. Reset does not work. Please advise.
