ICX 7150-C12P STUCK IN BOOT MODE SWITCH NOT WORKING WHAT NEXT?
nigelcov
1 REPLY 1
Yarenis
Hi @nigelcov
If the Switch is stuck in boot mode, there are a way to fix the issue by performing a software recovery, let me add the guide, Please read the guide carefully before start the troubleshooting.
Note: after fixing the issue of the Switch been stuck in boot mode, please perform an upgrade to the code 08095g UFI and upgrade both partitions with the switching code file named SPS08095gufi.bin, so perform the software recovery using the code 08090k with the upgrade image file named SPS08090k.bin, then when the switch is back to normal upgrade to the file SPS08095gufi.bin for both partitions primary and secondary.
Yarenis Hernández.
Technical Support Engineer | L2 TAC Wired | Lennar Home Community
