07-02-2023 07:17 PM
I lost power briefly and all my WAPs have stopped working, they don't have any power. I have searched for different solutions on this forum but have not had any success so far. Please help
07-03-2023 01:11 AM
Hi @Pantwi
Is this a Lennar setup ? If not do you know if these APs are unleash or managed by any other controller ? Assuming these are Unleash you can try setting the wifi again following below ?
https://www.youtube.com/watch?v=z4zbJcBSuuw&t=91s
https://www.youtube.com/watch?v=vFD_ByQWGH0
Best Regards
Vineet
07-03-2023 07:38 AM
Yes, this is a Lennar setup.
07-03-2023 07:43 AM
Hi @Pantwi
Let me route this case to Lennar support queue.for further assistance.
Best Regards
Vineet
07-03-2023 08:53 AM
Hi @Pantwi
Hope you are doing well!!!
As per the case description, I could understand that your RUCKUS setup is not working, and Access Points do not have power.
3. Is your Internet Connection from the Internet Service Provider (ISP) stable and working? (You could check this by connecting to your local router Wi-Fi or from an ethernet cable from Router to a laptop/PC).
