I lost power briefly and all my WAPs have stopped working, No power
Pantwi
I lost power briefly and all my WAPs have stopped working, they don't have any power. I have searched for different solutions on this forum but have not had any success so far. Please help
34 REPLIES 34
Vineet_nejwala
Hi @Pantwi
Is this a Lennar setup ? If not do you know if these APs are unleash or managed by any other controller ? Assuming these are Unleash you can try setting the wifi again following below ?
https://www.youtube.com/watch?v=z4zbJcBSuuw&t=91s
https://www.youtube.com/watch?v=vFD_ByQWGH0
Best Regards
Vineet
Pantwi
Yes, this is a Lennar setup.
Hi @Pantwi
Let me route this case to Lennar support queue.for further assistance.
Best Regards
Vineet
Hi @Pantwi
Hope you are doing well!!!
As per the case description, I could understand that your RUCKUS setup is not working, and Access Points do not have power.
1. Was this working before or is it a new installation? If it worked before, was there any power outage before you started facing this issue?
2. On your switch while it's plugged into the outlet, do you see any lights on? (Amber or green) Please let us know which lights are on. (Please refer to the below picture and share a picture of the same, showing the light status and the FULL Switch panel cable connections to the Switch ports)
3. Is your Internet Connection from the Internet Service Provider (ISP) stable and working? (You could check this by connecting to your local router Wi-Fi or from an ethernet cable from Router to a laptop/PC).
4. May I know how many Access Points are connected to the Switch? Could you please let me know the light status on the Access Points? Any of these lights are on (Please refer to the below picture and share a picture of the same)
