06-21-2023 09:20 AM
I had power trips and fluctuations yesterday 4-5 times. Since then switch is not working properly. Internet is very slow and connection drops intermittently. Tried restarting modem, router and switch no use still the same.
My setup : Modem -> Wifi Router -> Ruckus switch -> zoning points one in each floor.
Any help is much appreciated!!
08-07-2023 08:05 AM
Hi @rahulmandava
This issue is because your switch is running on the Routing code (SPR). The Switch should run on the Switching code (SPS) to avoid these issues for Lennar home users. Due to a power outage/power spike, the Switch boots up on the other partition which may be running on a ‘Routing Code’ results in causing this issue.
As I can see from the output you shared, your Switch is booted up on the secondary partition which is running on Routing code (SPR) as highlighted in the below screenshot.
copy flash flash secondary
Example:
NOTE: Please feel free to mark the post as ACCEPTED SOLUTIONS if your issue gets resolved.
07-05-2023 06:42 PM
Hi Deepu,
I tried the web GUI option shared above, but issue still persists. Could you please help me the next steps?
08-02-2023 07:29 AM
Can someone help me here ? I am not getting any response from last few weeks. I have setup temporary wifi bypassing ruckus, this is so annoying that it is not working in the first place and not getting support in the forum and no way to contact support directly.
08-02-2023 11:07 AM
admin test
08-02-2023 11:14 AM
Hi Imran, not sure what is your reply pertaining to. But the problem is I am still having the issue, as I mentioned in one of my replies earlier, I tried the web GUI option that one of your colleague suggested. Still ruckus is not working as expected or before. Please let me know what else I can try? If we can schedule a call that will be great as I have been facing the issue since more than a month and still no resolution.
08-02-2023 11:23 AM
Hi @rahulmandava
Apologies, effective November’2022, ‘Ruckus Support for Lennar Homes customers will no longer be handled by phone or email or remote session. We will be exclusively supporting customers via this community forum support model only.
I will assist you step by step, please don’t mind if any steps get repeated.
2. Is your Internet Connection from the Internet Service Provider (ISP) stable and working? (You could check this by connecting to your local router Wi-Fi or from an ethernet cable from Router to a laptop/PC).
3. May I know how many Access Points are connected to the Switch? Could you please let me know the light status on the Access Points? Any of these lights are on (Please refer to the below picture and share a picture of the same)
