06-21-2023 09:20 AM
I had power trips and fluctuations yesterday 4-5 times. Since then switch is not working properly. Internet is very slow and connection drops intermittently. Tried restarting modem, router and switch no use still the same.
My setup : Modem -> Wifi Router -> Ruckus switch -> zoning points one in each floor.
Any help is much appreciated!!
08-07-2023 08:05 AM
Hi @rahulmandava
This issue is because your switch is running on the Routing code (SPR). The Switch should run on the Switching code (SPS) to avoid these issues for Lennar home users. Due to a power outage/power spike, the Switch boots up on the other partition which may be running on a ‘Routing Code’ results in causing this issue.
As I can see from the output you shared, your Switch is booted up on the secondary partition which is running on Routing code (SPR) as highlighted in the below screenshot.
copy flash flash secondary
Example:
NOTE: Please feel free to mark the post as ACCEPTED SOLUTIONS if your issue gets resolved.
08-03-2023 04:48 AM
For 1 - please find the image.
For 2 - yes working fine via WiFi and directly.
For 3 - three access points. Please find the images.
please let me know what are the next steps.
08-03-2023 08:15 AM
Hi @rahulmandava
As per the light status of the RUCKUS ICX-7150-C12P Switch and Access Points, they seem to be in a normal state. And cable connections are connected properly.
This issue may happen when the Switch runs on the Routing code (SPR). The Switch should run on the Switching code (SPS) to avoid these issues for Lennar home users. If the Switch boots up on the other partition (Due to a power outage/power spike) which may be running on a ‘Routing Code’ results in causing this issue. To check the same please follow the below process.
ICX7150-C12 Router> OR
ICX7150-C12 Switch>
show version
show flash
08-05-2023 08:06 AM
Please find below screenshot and let me know the next steps. If I understand right, as you said ruckus is being run as router.
08-07-2023 08:05 AM
Hi @rahulmandava
Example:
08-07-2023 10:48 AM
This worked thanks!!
