- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
06-21-2023 09:20 AM
I had power trips and fluctuations yesterday 4-5 times. Since then switch is not working properly. Internet is very slow and connection drops intermittently. Tried restarting modem, router and switch no use still the same.
My setup : Modem -> Wifi Router -> Ruckus switch -> zoning points one in each floor.
Any help is much appreciated!!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-07-2023 08:05 AM
Hi @rahulmandava
This issue is because your switch is running on the Routing code (SPR). The Switch should run on the Switching code (SPS) to avoid these issues for Lennar home users. Due to a power outage/power spike, the Switch boots up on the other partition which may be running on a ‘Routing Code’ results in causing this issue.
As I can see from the output you shared, your Switch is booted up on the secondary partition which is running on Routing code (SPR) as highlighted in the below screenshot.
copy flash flash secondary
Example:
NOTE: Please feel free to mark the post as ACCEPTED SOLUTIONS if your issue gets resolved.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-23-2023 01:17 PM
I was able to login into switch now via IP Address login from browser. I don't see anything called firmware, but I do see this image version : (SW: Version 08.0.90dT213). Let me know if that is not the right one and / or if you need any information to further look into the issue ?
I do see few command options as well when I logged in, is there anything that I can run and see if the issue gets resolved ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-23-2023 09:08 PM - edited 06-26-2023 02:16 AM
Hi Rahulmandava
It looks like your Switch (ICX7150 Switch) may be booting from the secondary partition ( Note: Secondary partition contains the routing code) which is causing the bad connectivity issues. This could happen after multiple power outages, please follow up the next guide.
Guide#1 for CLI:
Guide#2 for CLI:
Note: if you have access to the Unleashed Dashboard and the Switch can be seen from there, it may look like the following image, ICX7150-C12-Router instead of ICX7150-C12-Switch, now before starting the steps of the guide, I will advise you to cable the computer directly to the Switch, since you will have a better connectivity than if you connect via wireless.
After fixing the issue of the Switch booting from the wrong partition, please perform an upgrade to the code 08095g UFI and upgrade both partitions primary and secondary with the switching code file named SPS08095gufi.bin, take into consideration that is the Switch is running a code lower than 08080 you need to upgrade twice, from the code you are to 08080f and then the recommended code 08095g UFI.
Upgrade a switch via Web GUI (ICX7150 Switch)
Please try the most common username and passwords ( This is key sensitive so please include capital letters )
Username:admin password: Ruckus!
Username:admin password: Ruckus1
Username:admin password: Lennar
Username:super password: sp-admin
Admin usernames and passwords for the Ruckus Wi-Fi Access Points/Switch for Lennar home users
Deepu Sekar
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-25-2023 06:35 PM
Hi Deepu, none of the links you shared are working. I get a page not found error.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-10-2023 09:48 AM
Hi Deepu, I have tried the option via Web GUI. Still it didn't resolve the issue. Could you please help me with the next steps?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-26-2023 02:17 AM
Hi Rahulmandava
Could you please check the above links now , I have verified it which is working fine now .
Regards ,
Deepu Sekar
