05-31-2025 08:59 AM
I purchased a Lennar home. The previous owner left the ruckus boxes but did not provide any information on how the smart home works. I called Lennar and they said they no longer deal with this? I have 2 Ruckus Unleashed 510 series, one per floor on the ceilings. My AT&T fiber comes in downstairs and there is a box on the wall upstairs with the Ruckus main hub. When I moved in, the box downstairs had a couple of wires (ethernet) but they recently replaced my modem and removed that box and replaced it with a wall plate with one fiber wire that connects to the BWG 320 modem. On the main Ruckus box upstairs, there are 2 lines labeled WAP that are connected (light beside upstairs WAP is green, no light by downstairs) as well as a line labeled Ethernet from AT&T (no light showing?). There are 3 other lines connected (showing green) labeled Samsung hub, Lutron Bridge, and Kevo Bridge. The only lights showing on the 510s upstairs and downstairs are power and ctl (blinking). I installed the app but it doesn’t “see” a ruckus device. I downloaded the Fing app but it doesn’t show a Ruckus device. I tried to logon to the website recommended to locate the AP address but it said server not working. Help? I have no idea how to connect the two 510s? When they switched the box downstairs, did it disconnect the ethernet to the main ruckus box upstairs?
05-31-2025 09:13 AM
I should add that my setup is not like the pictures provided in the “Lennar Setup”. My BGW 320 is located downstairs rather than in the wall box upstairs with the “Switch”. There is no label with an admin password or other sign in information anywhere.
06-02-2025 07:28 AM
Hello @Andrea ,
As per the case description, I understand that you have recently purchased Lennar Home and needs assistance in setting up Ruckus network.
For guidance on setting up your system, please refer to the RUCKUS Lennar Knowledge Base self-help article linked below. The article includes detailed instructions for the setup process.
Should you require further assistance or have any questions, please do not hesitate to reach out.
06-02-2025 01:31 PM
I have read the instruction manual provided in the link. First, the Ruckus Switch. On the device, I have a solid green light for the member ID status, the system status, and power. No other lights are showing on the switch. Does this indicate that it is connected to the internet? (The POE light is not on). The problem could be that when they installed the fiber box recently, they disconnected the ethernet. If this is the case then I’m not sure the problem can be solved since my router/modem box is downstairs and the Ruckus switch is upstairs. I could take the Switch downstairs and plug it into my modem/router but the AP connections (wires that plug into the Switch to connect the APs) are located upstairs.
06-02-2025 02:01 PM
Hello @Andrea ,
The ethernet cable and the Access points should be connected to one of the 12 ports on the Switch.
Could you please share the picture of the connection ports of the switch as shared in the below pic?
Also please confirm it the ethernet cable is plugged to one of the 12 ports in the Switch?
