02-28-2024 10:37 AM
No internet or wifi starting 3 AM this morning. I unplugged the Ruckus ICX-7150-C12P and am able to connect hardwired to the internet. If I plug it back in I lose the hardwired connection and still no wifi.
02-29-2024 07:18 AM
Hi @BillRamos
As you are using the PuTTY Key Generator is the reason for this window.
Please use the PuTTy application to get access to the Switch CLI.
Please refer to the below link to download the same.
Putty download link:https://www.putty.org/
02-29-2024 07:26 AM
Please see the attached video.
I have clicked on that link and downloaded Putty. After it installs it opens up to the window I've shared with you.
Putty link
02-29-2024 07:31 AM
Hi @BillRamos
Please search PuTTY in Windows search box and start PuTTy app. (Please refer to the below screenshot)
02-29-2024 08:16 AM
Figured it out. See attached. Still no good. I tried with SSH and Telnet.
Please keep in mind that if the Rickus is plugged in I have no hardwired connection.
02-29-2024 08:44 AM
Hi @BillRamos
Could you please log into the RUCKUS ICX-7150-C12P Switch on a web browser using the same IP address you are using on PuTTy?
Please confirm and let me know if you have any queries in this regard.
Thank you again for your patience and understanding
