Failed Switch - Stuck in crash mode
rleschber
Apologies as I do not have any experience with switches so please bear with me. I recently had a power outage and now my ICX7150 C12p is stuck in boot mode however, when I try to factory reset the lights keep blinking amber.  I tried to do the software recovery but I cannot connect to the switch.  The serial cable is not found. The only thing I see is Bluetooth over serial. I believe I may need to RMA this device.  Is this something support can help with?  Thank you!
1 REPLY 1
Imran_ruckus
Hi @rleschber
Hope you are doing well!!!
As per the case description, I could understand that your RUCKUS ICX-7150-C12P Switch is stuck in boot mode.
Once again, please try to reset the Switch as described below:
  • Remove power from the switch.
  • Press and hold the Reset button while applying power to the switch.
  • After all the system LEDs flash amber, release the Reset button.
As you tried the Software recovery process, could you please share the screenshot of the error you are getting? or please let us know at what step of the process you are stuck on.
Lennar Home Community.
