Enable command not working - amber light in the switch after power outage
vani
hello,
we had power outage for few seconds and then all the AP's are powered off. we followed the post to enable the switch but the "enable" or "ena" command are not working (RUCKUS Forums - How to Upgrade a Switch ICX-7150-C12P using a USB ... - CommScope RUCKUS Community F...)
Please help.
10 REPLIES 10
Valued Contributor III
Hi @vani
Greetings of the day,
For detailed understanding of the, please let us know the LED status of the access points using the below guide.
R510 LED lights
On your switch while it's plugged into the outlet, do you see any lights on the PWR ? (Amber or green) Please let us know which lights are on?
RUCKUS LED lights
Once you confirm this let us know you can also send us a photo/picture
there are no lights in the access points. the power in the switch has green light. switch.jpg
vani
Hi @vani
Based on your description, if the switch has one green and one yellow light, it means that the switch is stuck in boot mode. To solve this issue we need to perform factory reset process.
So please follow the below steps to perform factory reset.
  1.  Remove power from the switch.
If the resetting process doesn't work, we need to perform a software recovery.
Note: after fixing the issue of the Switch been stuck in boot mode, please perform an upgrade to the code 08095g UFI and upgrade both partitions with the switching code file named SPS08095gufi.bin, so perform the software recovery using the code 08090k with the upgrade image file named SPS08090k.bin, then when the switch is back to normal upgrade to the file SPS08095gufi.bin for both partitions primary and secondary.
