Devices not connecting
Mariabbetter
A few days ago, our home devices including Ring and Alexa as well as other devices that were connected to our ruckus router seemingly disconnected. The Network is still showing available, but nothing will connect to it. I rebooted the router by unplugging it, and all the lights show green and flashing but nothing still will connect. Any suggestions?
5 REPLIES 5
Jrshaw2
I’m having the same issue. Did you ever get yours fixed?
Hi @Jrshaw2
Base in your description, it looks like your Switch (ICX7150 Switch) may be booting from the wrong partition, let me add the guide to fix the issue.
Note: if you have access to the Unleashed Dashboard and the Switch can be seen from there, it may look like the following Image, ICX7150-C12-Router instead of ICX7150-C12-Switch, and please read the guides carefully before start the troubleshooting.
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-Fix-Routing-code-issu...
Yarenis Hernández
I am trying this troubleshooting method but none of the username/password combinations work. I did do a hard reset on both APs (via the reset button on the back) so I'm unsure if that has an impact on admin credentials. How can I get admin access to continue this trouble-shooting as I think this could resolve my issue
Hi @Anonymous
OK, factory resetting the access point will not fix the problem of your ICX 7150 Switch not booting from the correct partition, now the last credential you can try the credential you use to access the Unleashed APP if you know it?, let me add the combination as well, Because sometimes it happens that when the Switch is booting from the wrong partition you can use the Unleashed system credential, now if both credential combinations still not working to get access to the switch you need to perform an extra step to bypass the switch password; however, you need to get access to the console and from CLI(command line interface).
1:Password combination:
Usernames:           Passwords:
Admin                    sp-admin
Super                     Lennar
                               lennar
                               ruckus
                               Ruckus!
                               Ruckus1
                               admin
                               password
Username:                      Passwords:
  admin                             sp-admin
                                          Lennar
                                          lennar
                                          ruckus
                                          Ruckus!
                                          Ruckus1
                                          admin
                                          password
2:If still not working, perform the password recovery via console access.
A:Gain access via console:
How to console in the ICX-7150-12CP 'Ruckus Switch'
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-console-in-the-ICX-7150-12c-using-a-Windows-Machine/td-p/46759
RUCKUS ICX 7150 USB TYPE C CONSOLE (tutorial video for ICX)
https://www.youtube.com/watch?v=YXR4xhkw3q8
(Tutorial for MAC)
https://www.youtube.com/watch?v=1AcJokMm78U
B:Once you gained access, follow up the password recovery step to gain access to the switch.
Password Recovery on a Ruckus ICX(Tutorial video)
 https://www.youtube.com/watch?v=XJS28DWbHM4
Recovering from a lost password (CommScope Guide)
https://docs.commscope.com/bundle/fastiron-08090-securityguide/page/GUID-986D5DF0-BF7E-4327-9030-396433DFFD9D.html
3:No you have fixed the password issue, from console access you can fix the original booting from wrong code issue, by running the next commands:
ICX7150-C12 Router>enable
ICX7150-C12 Router>show flash  (you can confirm in which partition you have the correct code that will start with SPS example: SPS08080f.bin normally will be your primary partition)
ICX7150-C12 Router#copy flash flash secondary  (this will copy what is in your primary code to the secondary)
ICX7150-C12 Router# write memory
ICX7150-C12 Router#show flash  (now both partitions must start with the SPS before the code type)
ICX7150-C12 Router#Boot system flash primary yes
ICX7150-C12 Router#reload
Guide#1:
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-Fix-Routing-code-issues-on-Lennar-Home-users/td-p/47305
Guide#2:
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-solve-the-routing-code-issue-in-your-ICX7150-Switch/td-p/47335
Yarenis Hernández
