Contractor Tripped A Breaker and Now Connection is inconsistent
Kerickson516
I want to preface this with I do not speak technology.
Yesterday we had a contractor in our home who tripped a breaker that our ruckus was on. The power to the ruckus was only out for about 10 minutes, but when it got turned back on our Wi-Fi Internet has been spotty. Our Google speakers cannot connect and our ring keeps losing connection and regaining connection within the same 60 seconds every couple hours.
We tried to reset it but it was unsuccessful. We don’t know the actual problem, but we also don’t know enough to research the right answer.
Can anyone help?
We have lost power before but we have never had an issue like this with the ruckus.
TIA
18 REPLIES 18
Hello  @Kerickson516 ,
Thank you for sharing the information.
The ethernet cable light blinking amber is normal as it just indicates the data communication.
I would suggest you upgrade the firmware of the Switch since the Switch is on the older version.
We have shared the upgrade tool on the previous post.
Please follow the manual and upgrade the Switch version and let us know if you face the issue again.
Hi @Kerickson516 ,
Thank you.
