Connectivity Issues with ICX-7150-C12
kqnguyen1
Having connectivity issues with my ICX-7150 and APs (Lennar home). Connection is very spotty and slow (keeps dropping randomly). Have been reading through the forum for similar issues and seems it could be caused by a routing issue that could occur after a power outage. Already attempted to reset the switch and also unplug/reconnect.
Websites not loading
Devices getting disconnected randomly
Devices often not being able to connect to internet
Tried to access the switch via the web browser but no username/PW combinations seem to work. Need some help on next steps to find correct switch IP address, log in, etc., please advise thank you.
4 REPLIES 4
Lspray35
Did you get an answer to this yet? I’m having the exact same issue
Vásquez_Fer
Hi @kqnguyen1
Hope you are doing well!
If there was a blackout or power outage and the switch reboot because of that, most possible your switch starts running the wrong code which we call ‘routing code’ this is a know issue.
MAC address: Physical address of the device this never changes
An IP address is a unique address (logical) that identifies a device on the internet or a local network like your home (this can change and may not be the same as the one shown on the dashboard)
1- To fix this issue, we must identify the ‘currently’ IP address assigned by your local router to the switch
-We can try the IP address that shows in the dashboard copy and paste it in the URL if that redirects you to the login page for the ICX-7150-C12P that is the correct one if not.
I will leave you a guide how to perform an IP scanner on your local network to identify the switch IP address very easily.
2-Once we identified the IP address of the switch proceed to access remote to the device 'command Line'
Possible passwords and username for ssh /   access username : admin password : Lennar / username : admin password : Ruckus! / username : admin password : Ruckus1/ username : super password : sp-admin
Also Try Telnet option
If you can access to the Command line should look like this:
ICX7150-C12 Router>
3-Here is a quick guide to understand how to fix the 'routing code issue' but basically you need only need to run the following commands once you are on the command line 'CLI'
copy flash flash secondary
example:
ICX7150-24P Router#copy flash flash secondary (hit enter to accept the command and wait: until the flash finished )
ICX7150-24P Router#boot system flash secondary yes ( hit enter to accept the command  : the switch will reboot )
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-Fix-Routing-code-issu...
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/How-to-solve-the-routing-cod...
Or WEB access option
4-If the access via IP address is not possible here is a guide how to access to the Switch via console (cable access between your PC to the ICX 7150-C12P) in this case we need a USB type C to USB standard or Console cable Rj45 to USB.
Once you are log in the ICX-7150-C12P please follow up the same steps that are on point '3'
Best Regards
Fernando Vasquez
r_mendoza85
Did you ever get any help with this?
Hi @r_mendoza85
Please open your own post for better assistance.
Yarenis Hernández.
Technical Support Engineer | L2 TAC Wired | Lennar Home Community
