02-09-2024 07:26 AM
Internet connection is unstable when connected to AP. This was all working good during the first year of living in Lennar. Its been horrible for over 6 months now. The connection is unstable and speed is ridiculous when connected via AP. The connection and speed is fine when connected to internet via modem directly (by not using Ruckus).
Checking the documentation here shows to fix the routing code. Via GUI, the screenshots and steps are completely different than the current dashboard(GUI) that I see when I login to unleashed GUI.
Please share the new steps or directions to fix the routing code via new GUI.
Thank you
02-19-2024 02:53 PM
I'm still having this issue. Can you please help me out here.
Thank you
02-21-2024 08:15 AM
Hi @Deepika
Hope you are doing well!!!
Apologies for the delayed response.
Could you please try to log into the Switch CLI using Telnet option as SSH is not working.
Telnet – Port 23 (If SSH doesn’t work)
ICX7150-C12 Router> OR
ICX7150-C12 Switch>
show version
show flash
