02-20-2024 11:00 AM
My Ruckus ICX 7150-C12p no longer powers up. The status lights flash briefly when the unit is turned on or the power is recycled. The status lights do not respond when the status button is pressed. The switch is basically a paperweight. It does not route any internet signal to any ethernet port it is connected to or to the ruckus access point. It’s dead. Please note I’ve previously scoured these discussion boards for weeks for similar issues and have concluded that the only viable option is to replace the unit. There was no power surge, no issues with power to the unit and no other devices or any other pieces of equipment are experiencing any issues whatsoever. There seems to be no resolution on any of the other Lennar discussion boards for this issue other than unit replacement.
02-21-2024 05:11 AM
Hi @LennarRuckusGuy
As per the case description, I understand that your RUCKUS ICX-7150-C12P Switch is not powering up.
Could you please plug your ICX-7150-C12P Switch into a working power outlet and send us PICTURES and VIDEO of it showing the light status, and cord connected to the Switch and a working power outlet? Please refer to the below pictures as an example.
02-21-2024 06:44 AM
The still shots are attached and the video has been uploaded to the Google Drive link you provided. You now have pictures and video of the unit showing the light status, cord connected to the switch and a working power outlet as indicated by the power light on the other device plugged into the same outlet. Your pictures were used as the template for these photos to make certain everything you’ve requested is included. Thank you.
02-21-2024 07:18 AM
Hi @LennarRuckusGuy
Greetings of the day!!!
Thank you for sharing the requested PICTURES and a VIDEO.
Based on the troubleshooting done, your ICX-7150-C12P Switch is not powering up, and when plugged in, it flashes an amber light and then goes dark. And you confirm that the Switch is plugged into a well-known outlet/power source. However, the failure persists. This Switch unit Should be RMA (Return Merchandise Authorization) in simple words replacing it.
