07-06-2023 05:34 PM
I recently had a power outage and now my Switch is in Router mode. I followed the instructions at the below site and I was able to get the IP Address of my Switch (Router) but none of the login combinations work. Any idea of an alternative?
07-24-2023 08:41 AM
Hi @mrq201
Hope you are doing well!!!
Apologies for the inconvenience, as this case is raised by @HelpMePlease which now closed, I will be assisting you with your own post/case you have raised. (Please refer to the link below)
07-24-2023 06:19 AM
I tried this too and mine was not fixed. I then went to the Command Line to try that other step; however, I have a MAC and when I tried the SSH solution, it asks for a password. Thing is, NONE of the passwords that were suggested work.
