06-18-2025 12:48 PM
Bought a home that came with 3 Ruckus Wifi Extenders.
I do not have the password nor do i have access to the previous owners unfortunately.
is there a way to reset the password?
06-18-2025 02:28 PM
I saw Configure.Me-179D50 for a brief second, but it wouldnt let me connect to it.
what other options do i have?
06-19-2025 05:20 AM
Hi @ctang2277
Please make sure to perform a factory reset on only ONE connected Access Point to the Switch port. For example, if you have 3 R510 Access Points in your setup, remove the cables of any two Access Points from the Switch ports, and perform the factory reset only on the ONE connected access point to the Switch. Once you complete it, connect the unplugged Access points' cables back to the Switch ports, and it will sync up with the configurations from the factory reset Access Point.
Please let me know how it goes.
06-23-2025 06:27 AM
Hi @ctang2277
Thank you.
06-25-2025 05:29 AM
Hi @ctang2277
Thank you.
06-27-2025 07:06 AM
Hi @ctang2277
Thank you.
