Both APs are dead and Ring Bell doesn’t have power
Karupasu
This is extremely frustrating and unsafe! Help needed!
Both APs are not getting a signal from Ruckus. Ring bell doesn’t have power. Saw some posts of complicated resets. Can someone please respond asap!
2 REPLIES 2
Karupasu
This has happened a few times in the past and a Ruckus router power off and on has solved it. This time it didn’t.
Hi @Karupasu
Hope you are doing well!!!
As per the case description, I could understand that your RUCKUS setup is not working, and Access Points do not have power.
1. Was there any power outage before you started facing this issue?
2. On your switch while it's plugged into the outlet, do you see any lights on? (Amber or green) Please let us know which lights are on. (Please refer to the below picture and share a picture of the same, showing the light status and the FULL Switch panel cable connections to the Switch ports)
3. Is your Internet Connection from the Internet Service Provider (ISP) stable and working? (You could check this by connecting to your local router Wi-Fi or from an ethernet cable from Router to a laptop/PC).
4. May I know how many Access Points are connected to the Switch? Could you please let me know the light status on the Access Points? Any of these lights are on (Please refer to the below picture and share a picture of the same)
