07-31-2023 05:01 PM
This is extremely frustrating and unsafe! Help needed!
Both APs are not getting a signal from Ruckus. Ring bell doesn’t have power. Saw some posts of complicated resets. Can someone please respond asap!
07-31-2023 05:03 PM
This has happened a few times in the past and a Ruckus router power off and on has solved it. This time it didn’t.
07-31-2023 05:06 PM
Hi @Karupasu
Hope you are doing well!!!
As per the case description, I could understand that your RUCKUS setup is not working, and Access Points do not have power.
1. Was there any power outage before you started facing this issue?
3. Is your Internet Connection from the Internet Service Provider (ISP) stable and working? (You could check this by connecting to your local router Wi-Fi or from an ethernet cable from Router to a laptop/PC).
