05-08-2023 12:25 PM
My access point suddenly went into red and stuck in red light event after disconnecting and reconnecting. any help can be appreciated
05-11-2023 04:57 PM
Hi @krkogant
Based on the troubleshooting done, and you confirm after performing the reset of the Access Point, and checking all the connectivity and connections, the failure persists. This Access Point Unit Should be RMA (Return Merchandise Authorization) in simple words replacing it.
